Greg`s MX3 worklog
    Originally posted by Bax View Post
    He still needs to do some more work done to that megasquirt
    he is behind my old and slow spooling vj-23 and the stock gtr ecu
    http://www.youtube.com/watch?v=jWm4Y...eature=related
    That's the real video of this day...
    thats when i got my clutch fried!!!! your chicken house i slow as hell bax!!!!
    gtr sucks! bp+t ftw!!!!
    sigpicOf all the things i`ve lost.. i miss my mind the most....
      Well hello from the future! :D
      Car was unused for about 8 years give or take.
      What do you suggest doing before starting it up after so long?
        Is there gas in it?
        1990 Protege 4WD
        1 3 5
        2 4 R
          Yes there was , is there a drain plug?
            Maybe. I'm not sure about the MX-3. I'd get that gas out of there, and check the basics like oil and filters. Maybe spark plugs and distributor cap too.
            1990 Protege 4WD
            1 3 5
            2 4 R
              Will do! does it make sense to prime the engine without the pump fuse and with spark plugs pulled just to build up oil pressure before starting the engine ?
                Couldn't hurt, right? Or just pour a little oil in the combustion chambers while you have the plugs out...
                1990 Protege 4WD
                1 3 5
                2 4 R
                  definitely prime the engine a bit. I would pull the plugs before doing so that way you aren't actually fighting compression while trying to build oil pressure
                    Thank you! Will do !!
                      Car started fine! Now it just needs a lot of parts :D
                      Thank you for all the info :D
                        glad to hear!!
                          Nice.
                          1990 Protege 4WD
                          1 3 5
                          2 4 R
                            upload the images to CP so we can see them
                              I'm a newbie, have been looking through the posts since the beginning, of course the first photos with the red leather seats looked very extravagant.
                                i'm a newbie, wondering where the heck did everybody go!!!
                                1993 Mercury Tracer, KLDE VItara build swap, Compound turbos, 12 injectors, 2 wastegates, 2 Megasquirts, 2 axles, 2 everything, why not
                                2nd Compounded KL in the world
